Zum Hauptinhalt wechseln
GameSir T4 Pro Battery Replacement
Was du brauchst
  1. GameSir T4 Pro Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
    Frag FixBot
    Kommentar hinzufügen
  2. GameSir T4 Pro Battery Replacement: Schritt 2, Bild 1 von 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
    Frag FixBot
  3. GameSir T4 Pro Battery Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic spudger, wiggle the connection out of place.
    Frag FixBot
  4. GameSir T4 Pro Battery Replacement: Schritt 4, Bild 1 von 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
    Frag FixBot
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
Battery Model is pl502450 600mah
3.7v
Eugene Eugenio - Antwort Teilen
Where can I buy this battery? Do You have a link to it?
Roberto Barros - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 23
Letzte 30 Tage: 124
Insgesamt: 4,751
