Zum Hauptinhalt wechseln
GameSir T4 Pro Charging Port Replacement
Was du brauchst
  1. GameSir T4 Pro Charging Port Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
    Frag FixBot
    Kommentar hinzufügen
  2. GameSir T4 Pro Charging Port Replacement: Schritt 2, Bild 1 von 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
    Frag FixBot
  3. GameSir T4 Pro Charging Port Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic spudger, wiggle the connection out of place.
    Frag FixBot
  4. GameSir T4 Pro Charging Port Replacement: Schritt 4, Bild 1 von 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
    Frag FixBot
  5. GameSir T4 Pro Charging Port Replacement, Charging Port: Schritt 5, Bild 1 von 2 GameSir T4 Pro Charging Port Replacement, Charging Port: Schritt 5, Bild 2 von 2
    • Use the needle nose pliers to remove the plastic connection from the motherboard.
    • You may hold the wires for stability, but do not tug on the wires.
    Frag FixBot
  6. GameSir T4 Pro Charging Port Replacement: Schritt 6, Bild 1 von 2 GameSir T4 Pro Charging Port Replacement: Schritt 6, Bild 2 von 2
    • Remove the two 5mm screws on the charging port and take out the old charging port.
    Frag FixBot
  7. GameSir T4 Pro Charging Port Replacement: Schritt 7, Bild 1 von 2 GameSir T4 Pro Charging Port Replacement: Schritt 7, Bild 2 von 2
    • Put your new compatible charging port in place.
    • Make sure to screw in the 5mm screws into your new charing port
    Frag FixBot
Abschluss
1 Kommentar zur Anleitung
Where i can buy the charging port? Some buttons isnt working so when i was trying to solve the problem with contact cleaner i ended up breaking the soldered connection
Eron Araújo - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 36
Insgesamt: 1,557
