Zum Hauptinhalt wechseln
GameSir T4 Pro Directional Pad Replacement
Was du brauchst
  1. GameSir T4 Pro Directional Pad Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Directional Pad Replacement: Schritt 2, Bild 1 von 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Directional Pad Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Directional Pad Replacement: Schritt 4, Bild 1 von 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Directional Pad Replacement, Directional Pad: Schritt 5, Bild 1 von 2 GameSir T4 Pro Directional Pad Replacement, Directional Pad: Schritt 5, Bild 2 von 2
    • To get to the directional pad (d-pad), remove the three 5mm screws on the motherboard.
  6. GameSir T4 Pro Directional Pad Replacement: Schritt 6, Bild 1 von 1
    • Disconnect all white connectors from the motherboard.
  7. GameSir T4 Pro Directional Pad Replacement: Schritt 7, Bild 1 von 1
    • Carefully pull the motherboard away to reveal the front panel.
  8. GameSir T4 Pro Directional Pad Replacement: Schritt 8, Bild 1 von 1
    • Remove the d-pad from the front panel.
  9. GameSir T4 Pro Directional Pad Replacement: Schritt 9, Bild 1 von 1
    • Place your new d-pad in place.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 32
Insgesamt: 707
