Einleitung
This guide will help you repair the directional pad on your GameSir Pro T4.
Directional pads need replacement after wear and tear over time or if it somehow cracks.
Was du brauchst
Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
Apply a slow, but consistent pull to the old 600 maH battery.
Attach new battery onto the pad.
To get to the directional pad (d-pad), remove the three 5mm screws on the motherboard.
2 weitere Personen haben diese Anleitung absolviert.
