Zum Hauptinhalt wechseln
GameSir T4 Pro Joystick Replacement
Was du brauchst
  1. GameSir T4 Pro Joystick Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using the Phillips 1 screwdriver, gently turn the screw to the left (repeat this step until all four screws are taken out).
  2. GameSir T4 Pro Joystick Replacement: Schritt 2, Bild 1 von 1
    • Use your iFixit opening tool to break the seam of the back of your controller.
    • Be careful when pulling apart, as the charging port wires are connected to both sides of the controller.
  3. GameSir T4 Pro Joystick Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic spudger, wiggle the connection out of place.
  4. GameSir T4 Pro Joystick Replacement: Schritt 4, Bild 1 von 1
    • Apply a slow, but consistent pull to the old 600 maH battery.
    • Attach new battery onto the pad.
  5. GameSir T4 Pro Joystick Replacement, Joystick: Schritt 5, Bild 1 von 2 GameSir T4 Pro Joystick Replacement, Joystick: Schritt 5, Bild 2 von 2
    • Disconnect the rumblers from the motherboard
    • Be careful not to pull the wires while disconnecting rumbler
  6. GameSir T4 Pro Joystick Replacement: Schritt 6, Bild 1 von 1
    • Using the screwdriver, remove the 5 mm screws from the motherboard
  7. GameSir T4 Pro Joystick Replacement: Schritt 7, Bild 1 von 2 GameSir T4 Pro Joystick Replacement: Schritt 7, Bild 2 von 2
    • Using the wedge tool, pop the joystick out
  8. GameSir T4 Pro Joystick Replacement: Schritt 8, Bild 1 von 2 GameSir T4 Pro Joystick Replacement: Schritt 8, Bild 2 von 2
    • Make sure the square of the joystick matches the square of the pad and pop it in place.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
3 Kommentare
I bought ps4 joysticks for the repair, but ps4 joysticks seems larger so it's stuck
Mohamed NACERI - Antwort
PlayStation4 stick is not compatible with GameSir T4 Pro. The stick for the Nintendo Switch PRO controller does not interfere, but this also requires processing for installation.
NAKIRI - Antwort
It appears that you will need to remove the light diffuser(white tubular plastic sleeve) from the case to make the parts fit.
NAKIRI -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 39
Letzte 30 Tage: 168
Insgesamt: 3,848
