Einleitung
This guide goes over how to replace the motherboard on a GameSirT4 Pro controller. If your controller is having major problems with multiple components, replacing the motherboard may solve the problem.
Was du brauchst
Remove the following screws on the back case using a Phillips screwdriver:
Two 9.2 mm
Two 11.3 mm
Insert an opening tool in the seam between the front and back case.
Pry around the perimeter until the back case releases.
Gently pry the battery off of the motherboard, with care not to bend the cell.
Grip the white battery connector with tweezers and pull it directly out of its motherboard port.
Remove the three 7.1 mm Phillips #0 screws from the motherboard.
Remove the two 7.1 mm Phillips #0 screws that secure the trigger assemblies.
Eine weitere Person hat diese Anleitung absolviert.
