Zum Hauptinhalt wechseln
GameSir X2 Type-C Right Joystick Replacement
Was du brauchst
  1. GameSir X2 Type-C Right Joystick Replacement, Back Cover: Schritt 1, Bild 1 von 2 GameSir X2 Type-C Right Joystick Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Turn the device so the back faces you.
    Frag FixBot
    Kommentar hinzufügen
  2. GameSir X2 Type-C Right Joystick Replacement: Schritt 2, Bild 1 von 2 GameSir X2 Type-C Right Joystick Replacement: Schritt 2, Bild 2 von 2
    • Remove the eight 6 mm T6 Torx screws.
    Frag FixBot
  3. GameSir X2 Type-C Right Joystick Replacement: Schritt 3, Bild 1 von 1
    • Use a straight edge to remove the rubber pad on the front of the device.
    Frag FixBot
  4. GameSir X2 Type-C Right Joystick Replacement: Schritt 4, Bild 1 von 2 GameSir X2 Type-C Right Joystick Replacement: Schritt 4, Bild 2 von 2
    • Remove the four 4.5 mm screws with a Phillips #000 screwdriver.
    Frag FixBot
  5. GameSir X2 Type-C Right Joystick Replacement: Schritt 5, Bild 1 von 2 GameSir X2 Type-C Right Joystick Replacement: Schritt 5, Bild 2 von 2
    • Use a straight edge to pry open the controller, following the seam on the controller.
    • Some force is necessary, but be careful not to damage any of the clips holding the controller together.
    Frag FixBot
  6. GameSir X2 Type-C Right Joystick Replacement, Right Joystick: Schritt 6, Bild 1 von 3 GameSir X2 Type-C Right Joystick Replacement, Right Joystick: Schritt 6, Bild 2 von 3 GameSir X2 Type-C Right Joystick Replacement, Right Joystick: Schritt 6, Bild 3 von 3
    • Remove six 4.5 mm screws using the Phillips #000 screwdriver.
    Frag FixBot
  7. GameSir X2 Type-C Right Joystick Replacement: Schritt 7, Bild 1 von 2 GameSir X2 Type-C Right Joystick Replacement: Schritt 7, Bild 2 von 2
    • Remove the left panel of the back cover to expose the joystick.
    • The joystick is attached to the black board.
    Frag FixBot
  8. GameSir X2 Type-C Right Joystick Replacement: Schritt 8, Bild 1 von 2 GameSir X2 Type-C Right Joystick Replacement: Schritt 8, Bild 2 von 2
    • Remove three 6 mm screws using a Phillips #00 screwdriver.
    Frag FixBot
  9. GameSir X2 Type-C Right Joystick Replacement: Schritt 9, Bild 1 von 2 GameSir X2 Type-C Right Joystick Replacement: Schritt 9, Bild 2 von 2
    • Pull the joystick assembly out.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 46
Insgesamt: 854
