Einleitung
This guide shows how to replace the D-Pad on the GameSir X2s Type-C Mobile Gaming Controller. The GameSir X2s Type-C is a USB-C mobile controller designed for Android devices and USB-C–compatible phones, including the iPhone 15 series.
The D-Pad is responsible for directional inputs such as up, down, left, and right. It is commonly used for movement, menu navigation, and precision control in many games. Replacing the D-Pad can restore accurate directional input and improve overall gameplay performance.
Was du brauchst
Use a 000 Phillips screwdriver to remove the following eight silver fine-thread 6mm screws.
Flip the controller upright.
Remove the four silver fine-thread 4.5mm screws under the rubber grip using the 000 Phillips screwdriver.
Flip the GameSir X2s Type-C to the back.
Using a prying tool around the lip, where both pieces of plastic meet, run that around the hold device.
Pop off the plastic piece attached to the device.
Remove the blue strip connected to the board.
Remove six silver fine-thread 4.5mm screws and the two black fine-thread 4.5mm screws using a 000 Phillips screwdriver.
Remove the gold strip connected to the board.
Remove the three black fine-thread 4.5mm screws using the 000 Phillips screwdriver.
Remove the red and black wires from the board.
Remove the board from the GameSir X2s Type-C.
Remove the 3 black fine-thread 4.5mm screws from behind the right trigger using a 000 Phillips screwdriver.
Remove the 3 black fine-thread 4.5mm screws from the board using a 000 Phillips screwdriver.
Eine weitere Person hat diese Anleitung absolviert.
