Zum Hauptinhalt wechseln
GameSir X2s Type-C Face Buttons Replacement
Was du brauchst
  1. GameSir X2s Type-C Face Buttons Replacement, Back: Schritt 1, Bild 1 von 2 GameSir X2s Type-C Face Buttons Replacement, Back: Schritt 1, Bild 2 von 2
    • Use a 000 Phillips screwdriver to remove the following eight silver fine-thread 6mm screws.
    • Flip the controller upright.
    Frag FixBot
    Kommentar hinzufügen
  2. GameSir X2s Type-C Face Buttons Replacement: Schritt 2, Bild 1 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 2, Bild 2 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 2, Bild 3 von 3
    • Remove the four silver fine-thread 4.5mm screws under the rubber grip using the 000 Phillips screwdriver.
    • Flip the GameSir X2s Type-C to the back.
    • Using a prying tool around the lip, where both pieces of plastic meet, run that around the hold device.
    • Pop off the plastic piece attached to the device.
    Frag FixBot
  3. GameSir X2s Type-C Face Buttons Replacement: Schritt 3, Bild 1 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 3, Bild 2 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 3, Bild 3 von 3
    • Remove the blue strip connected to the board.
    • Remove six silver fine-thread 4.5mm screws and the two black fine-thread 4.5mm screws using a 000 Phillips screwdriver.
    • Remove the gold strip connected to the board.
    Frag FixBot
  4. GameSir X2s Type-C Face Buttons Replacement: Schritt 4, Bild 1 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 4, Bild 2 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 4, Bild 3 von 3
    • Remove the three black fine-thread 4.5mm screws using the 000 Phillips screwdriver.
    • Remove the red and black wires from the board.
    • Remove the board from the GameSir X2s Type-C.
    Frag FixBot
  5. GameSir X2s Type-C Face Buttons Replacement: Schritt 5, Bild 1 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 5, Bild 2 von 3 GameSir X2s Type-C Face Buttons Replacement: Schritt 5, Bild 3 von 3
    • Remove the 3 black fine-thread 4.5mm screws from behind the right trigger using a 000 Phillips screwdriver.
    • Remove the 3 black fine-thread 4.5mm screws from the board using a 000 Phillips screwdriver.
    Frag FixBot
  6. GameSir X2s Type-C Face Buttons Replacement: Schritt 6, Bild 1 von 1
    • Remove the black electrical board from the GameSir X2s Type-C.
    Frag FixBot
  7. GameSir X2s Type-C Face Buttons Replacement, Face Buttons: Schritt 7, Bild 1 von 1
    • Remove the face buttons from the GameSir X2s and replace them with new face buttons.
    Frag FixBot
Abschluss
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 9
Letzte 30 Tage: 26
Insgesamt: 162
