Einleitung
This guide demonstrates how to replace the left trigger (LT) on the GameSir X2s Type-C.
The left trigger is commonly used for secondary actions such as aiming, braking, or special functions. A damaged or malfunctioning trigger can prevent precise control and negatively affect gameplay.
Was du brauchst
Use a 000 Phillips screwdriver to remove the following eight silver fine-thread 6mm screws.
Flip the controller upright.
Remove the four silver fine-thread 4.5mm screws under the rubber grip using the 000 Phillips screwdriver.
Flip the GameSir X2s Type-C to the back.
Using a prying tool around the lip, where both pieces of plastic meet, run that around the hold device.
Pop off the plastic piece attached to the device.
Remove the blue strip connected to the board.
Remove six silver fine-thread 4.5mm screws and the two black fine-thread 4.5mm screws using a 000 Phillips screwdriver.
Remove the gold strip connected to the board.
Remove the three black fine-thread 4.5mm screws using the 000 Phillips screwdriver.
Remove the red and black wires from the board.
Remove the board from the GameSir X2s Type-C.
Remove the 3 black fine-thread 4.5mm screws from behind the right trigger using a 000 Phillips screwdriver.
Remove the 3 black fine-thread 4.5mm screws from the board using a 000 Phillips screwdriver.
Remove the four black fine-threaded black 4.5mm screws with 000 Phillips screwdriver.
