Einleitung
After many hours of use, the buttons on the Gamecube Controller can become too loose or stick. This guide will provide instructions on how to replace the buttons of the GameStop GS3 Gamecube Controller. There are ten total buttons in this controller: left and right triggers, Z, turbo, D-pad, start/pause, A, B, X, and Y.
Was du brauchst
First, remove the 6 screws in the back panel and pull the back panel off.
Separate the halves of the controller. However, be careful when separating due to the little wires that could get mixed up.
Finally remove the screws holding in the right and left triggers. It's easiest to hold the trigger together as shown in the third picture. Remove both the left and right trigger, and then you have successfully removed your back panel.
Hold the controller as shown in the picture so that you can remove the circuit board.
Now that the back panel has been removed it should be easy to snap off the "Z" and "TURBO" buttons as shown in the images.
Remove the two screws on the motherboard so that you can remove the motherboard from the front cover.
