Zum Hauptinhalt wechseln
GameStop GS3 GameCube Controller joysticks replacement
Was du brauchst
  1. GameStop GS3 GameCube Controller joysticks replacement, Joysticks: Schritt 1, Bild 1 von 2 GameStop GS3 GameCube Controller joysticks replacement, Joysticks: Schritt 1, Bild 2 von 2
    • Loosen and remove the 6 screws located on the back of the controller using your Phillips Screwdriver.
  2. GameStop GS3 GameCube Controller joysticks replacement: Schritt 2, Bild 1 von 1
    • Carefully pry apart the top and bottom covers.
  3. GameStop GS3 GameCube Controller joysticks replacement: Schritt 3, Bild 1 von 3 GameStop GS3 GameCube Controller joysticks replacement: Schritt 3, Bild 2 von 3 GameStop GS3 GameCube Controller joysticks replacement: Schritt 3, Bild 3 von 3
    • After separation, locate the rumble motor that is attached to the bottom cover of the controller.
    • Loosen and remove the 2 screws that are holding the rumble motor in place.
    • Lift and remove the rumble motor from the case.
  4. GameStop GS3 GameCube Controller joysticks replacement: Schritt 4, Bild 1 von 3 GameStop GS3 GameCube Controller joysticks replacement: Schritt 4, Bild 2 von 3 GameStop GS3 GameCube Controller joysticks replacement: Schritt 4, Bild 3 von 3
    • On the top cover of the controller, locate the green portion of the motherboard.
    • Loosen and remove the 1 screw in the upper left side of the green motherboard.
    • Turn the green motherboard over and attached to the motherboard will be the yellow c-stick.
    • Firmly, but carefully, pull the c-stick off, and clean around the area before reattaching or replacing the c-stick.
    • After cleaning or replacing the c-stick, reattach the green motherboard piece to the orange motherboard piece.
  5. GameStop GS3 GameCube Controller joysticks replacement: Schritt 5, Bild 1 von 3 GameStop GS3 GameCube Controller joysticks replacement: Schritt 5, Bild 2 von 3 GameStop GS3 GameCube Controller joysticks replacement: Schritt 5, Bild 3 von 3
    • Finally, loosen and remove the 2 screws located on the orange motherboard.
    • Pull up and remove the motherboard from the top cover. Then turn the motherboard over.
    • Locate the gray joystick that is attached to the left side of the motherboard.
    • Similarly to the yellow c-stick, firmly, but carefully, pull the gray joystick off, and clean around the area before reattaching or replacing the joystick.
Abschluss
UMass Dartmouth, Team 3-5, Isaacson Fall 2016 Mitglied von UMass Dartmouth, Team 3-5, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 20
Insgesamt: 1,128
