Einleitung
This guide will walk you through the process of replacing a battery that won't charge anymore in a Garden Creations JB5629.
Was du brauchst
Take the Gardens Creations JB5629 in hand.
Make sure the device is turned off.
Remove the garden stake by pulling it away from the bottom plastic tube.
Remove the first plastic tube by pulling it away from the tube connector.
Remove the tube connector by pulling it away from the top plastic tube.
Remove the top plastic tube by pulling it away from the lamp shade.
Remove the lamp shade by twisting it away from the lamp head.
Remove the battery cover by pushing down on the tab.
Replace the battery with 1 AA 1.2 V NiCd rechargeable battery.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
