Zum Hauptinhalt wechseln
Garden Creations JB5629 Battery Replacement
Was du brauchst
  1. Garden Creations JB5629 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Take the Gardens Creations JB5629 in hand.
    • Make sure the device is turned off.
  2. Garden Creations JB5629 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the garden stake by pulling it away from the bottom plastic tube.
    • Remove the first plastic tube by pulling it away from the tube connector.
    • Remove the tube connector by pulling it away from the top plastic tube.
    • Remove the top plastic tube by pulling it away from the lamp shade.
    • Remove the lamp shade by twisting it away from the lamp head.
  3. Garden Creations JB5629 Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery cover by pushing down on the tab.
    • Replace the battery with 1 AA 1.2 V NiCd rechargeable battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 1-32, Donnelly Fall 2014 Mitglied von USF Tampa, Team 1-32, Donnelly Fall 2014
USFT-DONNELLY-F14S1G32
1 Mitglied
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 8
Insgesamt: 156
