Einleitung
Be very careful when handling connector wires, as they are incredibly easily broken. This guide is unique only in removing the circuit board from the screen.
Was du brauchst
Remove the six T5 Torx 6.32mm screws securing the back cover to the watch.
Schritt 3 Water Proof Gasket
Achtung: Schritt 3 stammt von einer Anleitung, die derzeit bearbeitet wird.
Remove the orange gasket.
Use a metal spudger to remove the golden retaining clip from the screen. There will be some adhesive to break.
Unhinge the black retaining hinge by prying it open with the metal spudger; Your fingernails will work as well.
