Zum Hauptinhalt wechseln
Garmin Dash Cam 20 Camera Lens Replacement
Was du brauchst
  1. Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: Schritt 1, Bild 1 von 2 Garmin Dash Cam 20 Camera Lens Replacement, Internal Assembly: Schritt 1, Bild 2 von 2
    • Be sure to turn off the Dash Cam by pressing the power button.
  2. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 2, Bild 1 von 2 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 2, Bild 2 von 2
    • Rotate the Dash Cam to where the socket faces you.
    • Remove the 9 mm screw using the Torx T6 screwdriver.
  3. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 3, Bild 1 von 2 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 3, Bild 2 von 2
    • Remove the Dash Cam socket piece.
  4. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 4, Bild 1 von 2 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 4, Bild 2 von 2
    • Rotate the Dash Cam to where the product information faces you.
    • Remove the two 5 mm screws using the Torx T5 screwdriver.
  5. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 5, Bild 1 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 5, Bild 2 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 5, Bild 3 von 3
    • Remove top case from the bottom case.
    • The compact nature of the casing requires use of the metal spudger for needed leverage.
  6. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 6, Bild 1 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 6, Bild 2 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 6, Bild 3 von 3
    • Remove the two 5mm screws using the Torx T5 screwdriver
    • By removing the screws, the metal battery frame will now become free from the rest of the device.
  7. Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: Schritt 7, Bild 1 von 2 Garmin Dash Cam 20 Camera Lens Replacement, Motherboard Components: Schritt 7, Bild 2 von 2
    • This step shows the use of an incorrect tool. Always use an ESD safe tool, like a nylon spudger, when working with delicate internal components.
    • Use the nylon spudger to pry the corner of the case off of the motherboard.
  8. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 8, Bild 1 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 8, Bild 2 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 8, Bild 3 von 3
    • Remove the metal case off of the motherboard.
  9. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 9, Bild 1 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 9, Bild 2 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 9, Bild 3 von 3
    • Remove the battery connection.
  10. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 10, Bild 1 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 10, Bild 2 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 10, Bild 3 von 3
    • Remove the three 5 mm screws using the Torx T5 screwdriver.
  11. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 11, Bild 1 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 11, Bild 2 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 11, Bild 3 von 3
    • Use tweezers to remove the connector on the top right of the motherboard.
  12. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 12, Bild 1 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 12, Bild 2 von 3 Garmin Dash Cam 20 Camera Lens Replacement: Schritt 12, Bild 3 von 3
    • Remove the motherboard from the case and flip to reveal SD connection.
    • Use tweezers to remove the connector next to the SD card slot.
  13. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 13, Bild 1 von 1
    • The motherboard is now removed aside from the copper strip and its connector.
    • Disconnect from the front case and the copper strip.
  14. Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: Schritt 14, Bild 1 von 2 Garmin Dash Cam 20 Camera Lens Replacement, Camera Lens: Schritt 14, Bild 2 von 2
    • Use the Torx T5 screwdriver to remove the two 5mm screws.
    • These screws hold the camera in place. Therefore, the lens will fall into the bottom case.
  15. Garmin Dash Cam 20 Camera Lens Replacement: Schritt 15, Bild 1 von 1
    • The camera lens is now detached.
Abschluss
USF Tampa, Team 2-1, Cagle Fall 2016 Mitglied von USF Tampa, Team 2-1, Cagle Fall 2016
USFT-CAGLE-F16S2G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 15
Insgesamt: 949
