Einleitung
This guide will explain how to open your Garmin, detach the battery from the motherboard, and remove the battery from the device safely and quickly.
Was du brauchst
Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
Turn the device over, laying it on its back with the screen facing upwards.
Lift the front panel away from the silver part of the back panel.
Grasp the battery wire near the motherboard and lift upward to detach the connector.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Completely useless as soon as you open the cover the old ribbon rips and you garmin is junk. Don’t waste your money
you have to be more careful with your stuff dude..
