Einleitung
This guide will show you how to properly and safely remove the Garmin Dezl 760LMT's screen from the motherboard and its casing.
Was du brauchst
Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
Turn the device over, laying it on its back with the screen facing upwards.
Lift the front panel away from the silver part of the back panel.
Lift the screen opposite where the "GARMIN" logo is located. Remove the clear tape holding the ribbon cable to the motherboard.
In diesem Schritt verwendetes Werkzeug:Anti-Static Wrist Strap$7.95
Find and lift the small grey hinge at the end of the ribbon cable.
Using a Torx T5 screwdriver, unscrew the four 7mm screws from the back plate of the screen.
Turn the screen over so that it is facing upwards.
Remove the front plate of the screen.
Lift the screen from its back casing.
2 Kommentare zur Anleitung
where can one by the replacement screen
