Zum Hauptinhalt wechseln
Garmin Dezl 760LMT Speaker Replacement
Was du brauchst
  1. Garmin Dezl 760LMT Speaker Replacement, Back Panel: Schritt 1, Bild 1 von 2 Garmin Dezl 760LMT Speaker Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Using a Torx T6 Screwdriver, remove the ten 7mm screws from the back panel.
  2. Garmin Dezl 760LMT Speaker Replacement: Schritt 2, Bild 1 von 3 Garmin Dezl 760LMT Speaker Replacement: Schritt 2, Bild 2 von 3 Garmin Dezl 760LMT Speaker Replacement: Schritt 2, Bild 3 von 3
    • Using a metal spudger, pry the device apart.
    • To recombine them, line up the two halves of the device and press them together.
  3. Garmin Dezl 760LMT Speaker Replacement: Schritt 3, Bild 1 von 1
    • Turn the device over, laying it on its back with the screen facing upwards.
    • Lift the front panel away from the silver part of the back panel.
    • Make sure not to rip the ribbon cable that is connected to the screen and the motherboard.
  4. Garmin Dezl 760LMT Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 Garmin Dezl 760LMT Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    • Using the sharp end of the metal probe, scrape away the wax around the base of the speaker.
    • Slide the metal probe underneath the speaker and pry upwards.
    • During reassembly, use electrical tape to hold the speaker into place.
  5. Garmin Dezl 760LMT Speaker Replacement: Schritt 5, Bild 1 von 2 Garmin Dezl 760LMT Speaker Replacement: Schritt 5, Bild 2 von 2
    • Grasp the speaker wire near the motherboard and lift upward to detach the connector.
Abschluss
Ryan Williams
763 Reputation
6 Anleitungen geschrieben
USF Tampa, Team 4-2, Passmore Fall 2016 Mitglied von USF Tampa, Team 4-2, Passmore Fall 2016
USFT-PASSMORE-F16S4G2
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 10
Insgesamt: 519
