Zum Hauptinhalt wechseln
Garmin Dezl 770LMT Battery Replacement
Was du brauchst
  1. Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: Schritt 1, Bild 1 von 2 Garmin Dezl 770LMT Battery Replacement, Back Panel Removal: Schritt 1, Bild 2 von 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Battery Replacement: Schritt 2, Bild 1 von 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Battery Replacement: Schritt 3, Bild 1 von 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Battery Replacement, Battery Replacement: Schritt 4, Bild 1 von 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: Schritt 4, Bild 2 von 3 Garmin Dezl 770LMT Battery Replacement, Battery Replacement: Schritt 4, Bild 3 von 3
    • Using a metal spudger, carefully pry the battery from the device.
    • The regular black nylon spudger should be used whenever possible, especially around batteries.
    • Before you place the battery back in, make sure to place some double-sided electrical tape to attach it to the case.
  5. Garmin Dezl 770LMT Battery Replacement: Schritt 5, Bild 1 von 2 Garmin Dezl 770LMT Battery Replacement: Schritt 5, Bild 2 von 2
    • Grasp the wire near the mother board and gently lift to detach the battery.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
USF Tampa, Team 1-3, Lacy Fall 2016 Mitglied von USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 36
Insgesamt: 6,107
