Zum Hauptinhalt wechseln
Garmin Dezl 770LMT Speaker Replacement
Was du brauchst
  1. Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: Schritt 1, Bild 1 von 2 Garmin Dezl 770LMT Speaker Replacement, Back Panel Removal: Schritt 1, Bild 2 von 2
    • Turn the device screen down and using the screwdriver remove all eight screws from the back plate.
  2. Garmin Dezl 770LMT Speaker Replacement: Schritt 2, Bild 1 von 1
    • Place a nylon spudger in the seam between the front and back panel and carefully lift around the edge of the device.
  3. Garmin Dezl 770LMT Speaker Replacement: Schritt 3, Bild 1 von 1
    • Use the spudger to pry apart the screen from all around the device.
    • Gently lift the screen so not to disconnect the ribbon attaching the screen to the motherboard.
  4. Garmin Dezl 770LMT Speaker Replacement, Speaker: Schritt 4, Bild 1 von 2 Garmin Dezl 770LMT Speaker Replacement, Speaker: Schritt 4, Bild 2 von 2
    • Using the sharp side of the spudger, scrape away the adhesive surrounding the speaker.
    • Slide the spudger beneath the speaker and pull it away from the case.
    • The regular black nylon spudger should be used whenever possible, especially around sensitive internal components.
  5. Garmin Dezl 770LMT Speaker Replacement: Schritt 5, Bild 1 von 2 Garmin Dezl 770LMT Speaker Replacement: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Grasp the wire connecting the motherboard and pull the wares connecting it.
    • Remember to wear an anti-static wrist strap when handling the motherboard.
Abschluss
USF Tampa, Team 1-3, Lacy Fall 2016 Mitglied von USF Tampa, Team 1-3, Lacy Fall 2016
USFT-LACY-F16S1G3
4 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
do u know where i can get a replacement speaker
markrushforth65 - Antwort
Hi where can I buy the speaker, i hardly use my deal 770 lm and speaker gave up.
Noel Borg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 994
