Zum Hauptinhalt wechseln
Garmin Drive 52 and Traffic Battery Replacement
Was du brauchst
  1. Garmin Drive 52 and Traffic Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Garmin Drive 52 and Traffic Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Garmin Drive 52 and Traffic Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Use a T5 Torx screwdriver to remove the four screws in the corners of the backside of the device.
    • If necessary, use a Jimmy or other pry tool to open the backside of the device.
  2. Garmin Drive 52 and Traffic Battery Replacement: Schritt 2, Bild 1 von 3 Garmin Drive 52 and Traffic Battery Replacement: Schritt 2, Bild 2 von 3 Garmin Drive 52 and Traffic Battery Replacement: Schritt 2, Bild 3 von 3
    • Once the back side is open, flip the ZIF connector's lock bar up then remove the connector.
  3. Garmin Drive 52 and Traffic Battery Replacement: Schritt 3, Bild 1 von 3 Garmin Drive 52 and Traffic Battery Replacement: Schritt 3, Bild 2 von 3 Garmin Drive 52 and Traffic Battery Replacement: Schritt 3, Bild 3 von 3
    • Use a T5 Torx screwdriver to unscrew the four screws securing the motherboard.
    • Gently detach the wiring from the motherboard and left the motherboard out.
    • Use a nylon spudger to gently lift the battery out.
    • Avoid using metal spudgers near batteries; puncturing or excessively warping batteries can be dangerous.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Jason Wilson
388 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 1-2, Petersen Fall 2022 Mitglied von UMass Dartmouth, Team 1-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G2
6 Mitglieder
Ein Kommentar
Guide is great. Step by step.
At the end you could probably forgo taking out the motherboard, but better safe than sorry. Only hard part was re-attaching the screen to the zip connector again. Small space, used a flat spidger to flip the zip connector down once I had the connector strip in place.
Thank you for this guide saved me $140 on a GPS.
Chris Massey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 53
Insgesamt: 842
