Zum Hauptinhalt wechseln
Garmin Drive 52 and Traffic Speaker Replacement
Was du brauchst
  1. Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: Schritt 1, Bild 1 von 3 Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: Schritt 1, Bild 2 von 3 Garmin Drive 52 and Traffic Speaker Replacement, Motherboard: Schritt 1, Bild 3 von 3
    • Pop the suction cup off of the device.
    • Unscrew the four T5 Torx screws on the back.
    • Carefully pry apart the front and back with a Jimmy.
    Frag FixBot
    Kommentar hinzufügen
  2. Garmin Drive 52 and Traffic Speaker Replacement: Schritt 2, Bild 1 von 1
    • With the top in hand, carefully apply pressure on the top of the screen to pop it out of the front of the case.
    Frag FixBot
  3. Garmin Drive 52 and Traffic Speaker Replacement: Schritt 3, Bild 1 von 2 Garmin Drive 52 and Traffic Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove the four Torx T5 screws.
    • Unplug the two connectors from the motherboard and lift it up and out.
    Frag FixBot
  4. Garmin Drive 52 and Traffic Speaker Replacement, Speaker: Schritt 4, Bild 1 von 1
    • Gently lift the speaker out.
    • Do not use a metal spudger or tool to pry the speaker or any components. Using incorrect tools could damage your device.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
UMass Dartmouth, Team 1-2, Petersen Fall 2022 Mitglied von UMass Dartmouth, Team 1-2, Petersen Fall 2022
UMASSD-PETERSEN-F22S1G2
6 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 20
Insgesamt: 262
