Zum Hauptinhalt wechseln
Garmin Drive 60LM Motherboard Replacement
Was du brauchst
  1. Garmin Drive 60LM Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 2 Garmin Drive 60LM Motherboard Replacement, Motherboard: Schritt 1, Bild 2 von 2
    • Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
  2. Garmin Drive 60LM Motherboard Replacement: Schritt 2, Bild 1 von 3 Garmin Drive 60LM Motherboard Replacement: Schritt 2, Bild 2 von 3 Garmin Drive 60LM Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the back panel using the metal spudger tool.
    • The metal spudger tool can cause damage to internal components.
    • Flip the device over with the screen facing upward and open the device.
  3. Garmin Drive 60LM Motherboard Replacement: Schritt 3, Bild 1 von 3 Garmin Drive 60LM Motherboard Replacement: Schritt 3, Bild 2 von 3 Garmin Drive 60LM Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use a plastic spudger to flip up the white clamp holding the orange ribbon in place to the motherboard.
    • Lift the screen and orange ribbon away from the motherboard.
    • The metal spudger pictured is not ESD safe. Use a plastic spudger instead.
  4. Garmin Drive 60LM Motherboard Replacement: Schritt 4, Bild 1 von 2 Garmin Drive 60LM Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Using the T4 Torx screwdriver, unscrew the four screws (1/2 cm, 5mm) from the motherboard.
    • Then, lift the motherboard out of its position.
  5. Garmin Drive 60LM Motherboard Replacement: Schritt 5, Bild 1 von 2 Garmin Drive 60LM Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Flip the motherboard over towards the right.
    • Then, carefully disconnect the two sets of wires that are connected to the battery and the speaker using your fingers.
    • Remove the motherboard.
Abschluss
Andy Flores
238 Reputation
2 Anleitungen geschrieben
Baylor, Team 3-3, Whitney Spring 2017 Mitglied von Baylor, Team 3-3, Whitney Spring 2017
BU-WHITNEY-S17S3G3
4 Mitglieder
3 Anleitungen geschrieben
2 Kommentare
Bonjour, ou trouver la carte mère ?
Hello, where can I find the motherboard?
th.lamouroux - Antwort
i lost the screws while replacing the batterry. where do ifind the screws
Carolyn Mock - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 31
Insgesamt: 1,395
