Einleitung
To replace the speaker in your device you will need a T4 Torx screwdriver, a metal spudger, a plastic spudger, and a replacement speaker. Be sure to have a large workspace to avoid mishandling or damaging the device components.
Was du brauchst
Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
Remove the back panel using the metal spudger tool.
Flip the device over with the screen facing upward and open the device.
Use a plastic spudger tool to lift the wires from behind the motherboard.
Carefully disconnect the wires attaching the speaker to the motherboard using your fingers.
Eine weitere Person hat diese Anleitung absolviert.
