Einleitung
To replace the speaker in your device you will need a T4 Torx screwdriver, a metal spudger, a plastic spudger, and a replacement speaker. Be sure to have a large workspace to avoid mishandling or damaging the device components.
Was du brauchst
Using the T4 Torx screwdriver, unscrew all four of the screws (1/4 inch, 6.35 mm) from the back panel of your device.
Remove the back panel using the metal spudger tool.
Flip the device over with the screen facing upward and open the device.
Use a plastic spudger tool to lift the wires from behind the motherboard.
Carefully disconnect the wires attaching the speaker to the motherboard using your fingers.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
