Einleitung
If there is an issue with your Garmin 1000 Edge (M/N F4ACGQ00) mount, use this guide to replace the back cover of your unit.
The back cover houses the device’s SIM card and battery as well. This guide can be used to gain access to these components as needed.
Was du brauchst
Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
Pull the front side of the device apart from the back side.
Disconnect the bronze SIM card flex cable from the motherboard with your finger.
Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
Eine weitere Person hat diese Anleitung absolviert.
