Zum Hauptinhalt wechseln
Garmin Edge 1000 Lithium-Ion Battery Replacement
Was du brauchst
  1. Garmin Edge 1000 Lithium-Ion Battery Replacement, Back Cover: Schritt 1, Bild 1 von 2 Garmin Edge 1000 Lithium-Ion Battery Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
    Frag FixBot
    Kommentar hinzufügen
  2. Garmin Edge 1000 Lithium-Ion Battery Replacement: Schritt 2, Bild 1 von 2 Garmin Edge 1000 Lithium-Ion Battery Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
    Frag FixBot
  3. Garmin Edge 1000 Lithium-Ion Battery Replacement, Lithium-Ion Battery: Schritt 3, Bild 1 von 2 Garmin Edge 1000 Lithium-Ion Battery Replacement, Lithium-Ion Battery: Schritt 3, Bild 2 von 2
    • Using the nylon spudger, pry the battery off of the back half of the device. Pull the battery away from the back cover.
    • Cut the two wires that connect the back cover to the battery using a pair of wire cutters.
    Frag FixBot
  4. Garmin Edge 1000 Lithium-Ion Battery Replacement: Schritt 4, Bild 1 von 1
    • Strip the ends of the red and silver wires connected to the back panel of the device using a pair of wire strippers.
    Frag FixBot
  5. Garmin Edge 1000 Lithium-Ion Battery Replacement: Schritt 5, Bild 1 von 1
    • Solder the silver wire from the new battery with the silver wire connected to the back panel of your device.
    • Repeat these steps with the red wire from the new battery and the wire from the back panel.
    Frag FixBot
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
1 Kommentar zur Anleitung
Hi Taylor, which battery (Voltage, size) did you use and where did you buy it? Is it a Lithium-Polymer? Thanks for letting me know. Btw, maybe not the best way to cut both battery wires, plus and minus, at the same time, as it short circuits the probably still working battery.
Klaus S. - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 83
Insgesamt: 6,966
