Zum Hauptinhalt wechseln
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
Was du brauchst
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: Schritt 1, Bild 1 von 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: Schritt 2, Bild 1 von 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: Schritt 3, Bild 1 von 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: Schritt 3, Bild 2 von 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: Schritt 3, Bild 3 von 3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
Abschluss
4 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 1,567
