Zum Hauptinhalt wechseln
Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement
Was du brauchst
  1. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: Schritt 1, Bild 1 von 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Back Cover: Schritt 1, Bild 2 von 2
    • Be sure the device is properly powered all the way off before starting the replacement.
    • Hold the device front side down. Remove the eight T6 Torx screws along the backside of the device.
    • Pull the front side of the device apart from the back side.
    Frag FixBot
    Kommentar hinzufügen
  2. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: Schritt 2, Bild 1 von 2 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the bronze SIM card flex cable from the motherboard with your finger.
    • Disconnect the battery cord to completely separate the front cover from the back cover of the device with your finger.
    Frag FixBot
  3. Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: Schritt 3, Bild 1 von 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: Schritt 3, Bild 2 von 3 Garmin Edge 1000 Micro SD+SIM Card Tray Holder Replacement, Micro SD+SIM Card Tray Holder Slot Flex Cable: Schritt 3, Bild 3 von 3
    • Take a metal spudger and use force to push the micro USB port out of its socket on the other end.
    • Use the metal spudger once again to use force and push the SIM card port out of its socket. This will allow you to remove this piece entirely and insert a new charging port into the same place.
    Frag FixBot
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
1 Kommentar zur Anleitung
Hello, Taylor et all. I have an issue with the Edge 1000 not reading the SD card. How do I know if this is a problem with the card slot and not the motherboard? This model is considered discontinued and I cannot expect help from Garmin. Regards.
Victor Neto - Antwort Teilen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 31
Insgesamt: 1,943
