Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
We will be replacing the battery in the Garmin Fenix 2 watch. You should have a Torx T9 screwdriver on hand and a nylon spudger.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing. Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing. Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
    • Use a Torx T9 screwdriver to remove these four .8mm screws and seperate the housing.
  2. Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery. Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
    • Use a spudger tool to disengage the power ribbon from the main board. Once the ribbon is disconnected you can separate the bottom piece of the housing that holds the battery.
  3. Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it. Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
    • Use the spudger tool again and wedge it in between the battery and the housing, pry until the battery starts to separate from the adhesive holding it in place. Once you have the battery disconnected you are ready to replace it.
    • Despite the fact that the metal spudger is shown being used in this step, make sure to use a plastic opening tool or nylon spudger to pry up the battery. The metal spudger has a much larger chance of puncturing the battery, and thus should not be used.
Abschluss
8 weitere Nutzer haben diese Anleitung absolviert.
Brandon Barger
1.147 Reputation
5 Anleitungen geschrieben
IUPUI, Team 54-4, Wilson Spring 2016 Mitglied von IUPUI, Team 54-4, Wilson Spring 2016
IUPUI-WILSON-S16S54G4
3 Mitglieder
can you tell us exactly which battery should be used? Thanks in advance!
fabrizionannini - Antwort
Look for: RouteJD Inc PD3032 3.7V 200mAh - I found one on Ebay
homanchris -
Are you certain that's the proper battery? Garmin's website says the Fenix 2 has a 500mAh capacity.
https://buy.garmin.com/en-US/US/into-spo...
L P -
Garmin's website says the battery is a 500mAh capacity. Are you certain that is the correct one?
L P - Antwort
After some research on eBay the correct battery size should be PD3555 3.7V which is 500mAh.
Yang - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 2
Letzten 7 Tage: 15
Letzten 30 Tage: 85
Insgesamt: 26,868
