Zum Hauptinhalt wechseln
Garmin Fenix 3 HR Battery Replacement
Was du brauchst
  1. Garmin Fenix 3 HR Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Garmin Fenix 3 HR Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Remove the five 7mm screws with H1.3 hex screwdriver.
  2. Garmin Fenix 3 HR Battery Replacement: Schritt 2, Bild 1 von 3 Garmin Fenix 3 HR Battery Replacement: Schritt 2, Bild 2 von 3 Garmin Fenix 3 HR Battery Replacement: Schritt 2, Bild 3 von 3
    • Use a plastic opening tool to remove the face of the device to expose the inner components.
    • There is one metal piece at the top of the face that is loose. This is the GPS antenna which will need to be removed as well.
    • Be careful with the ribbon that connects the motherboard to the display.
  3. Garmin Fenix 3 HR Battery Replacement: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Proceed to disconnect the ribbon from the motherboard using tweezers.
  4. Garmin Fenix 3 HR Battery Replacement: Schritt 4, Bild 1 von 2 Garmin Fenix 3 HR Battery Replacement: Schritt 4, Bild 2 von 2
    • Using a T5 screwdriver, remove the two 5mm screws.
    • The motherboard should now move freely.
  5. Garmin Fenix 3 HR Battery Replacement: Schritt 5, Bild 1 von 1
    • Another ribbon is attached to the top of the motherboard. Disconnect this ribbon.
  6. Garmin Fenix 3 HR Battery Replacement: Schritt 6, Bild 1 von 1
    • Disconnect wires connecting battery to motherboard.
  7. Garmin Fenix 3 HR Battery Replacement: Schritt 7, Bild 1 von 1
    • The battery is glued to the motherboard and will need pried off using the nylon spudger.
  8. Garmin Fenix 3 HR Battery Replacement: Schritt 8, Bild 1 von 1
    • Now attach the new battery with adhesive and reassemble.
Abschluss
40 weitere Nutzer:innen haben diese Anleitung absolviert.
Victor Tanguy
1.329 Reputation
1 Anleitung geschrieben
IUPUI, Team S1-G6, Harley Spring 2018 Mitglied von IUPUI, Team S1-G6, Harley Spring 2018
IUPUI-HARLEY-S18S1G6
3 Mitglieder
4 Anleitungen geschrieben
29 Kommentare
Does anybody do It in a fenix 5?
Fernando Alcaraz - Antwort
Same question. Fenix five /+ guide on the way?
Erik E123 -
Thank you. It saved me around over £100 to change the battery myself. Garmin quoted around £121 for battery replacement for out of warranty watch. I bought the battery around £15 and followed the guide to change the battery myself in my Fenix 3 watch. My watch does not have heart rate monitor, perhaps the ribon at step 5 is for HR monitor as I didn’t have it in my watch. Thanks again for simple, detailed and easy to follow instructions.
Asif Shafiq - Antwort
Where did you get the battery?
Alex -
Amazon or other 3 Party Sellerie use google for search the are tonns of Shops wich sell it
Andreas Kahl -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 111
Letzte 30 Tage: 472
Insgesamt: 66,001
