Einleitung
This guide will give you all the necessary steps to change your old motherboard for a new one.
Ersatzteile
Keine Ersatzteile angegeben.
Use a plastic opening tool to remove the face of the device to expose the inner components.
Another ribbon is attached from the underside of the motherboard. Disconnect this ribbon.
The battery is glued to the motherboard and will need pried off with a nylon spudger.
5 weitere Nutzer haben diese Anleitung absolviert.
2 Kommentare
And where would one source replacement motherboard?
donde puedo encontras placa.madre reeemplazo????
