Einleitung
Even the best electronics die out over time, especially devices used in harsh conditions. This guide will show how to replace the motherboard of your Garmin Fenix 3 if the electronics are showing signs of failure. You will need a T6 Torx screwdriver, a T5 Torx screwdriver, and a spudger.
Ersatzteile
Keine Ersatzteile angegeben.
Use a T6 screwdriver to remove the five 1.7 mm screws from the watch face.
Use a spudger to lift up and free the screen ribbon cable's press-fit connector from the motherboard.
Locate the two silver 1.4 mm T5 screws, and carefully unscrew them.
Lift the watch and turn it over one hand. The motherboard should fall out easily.
Using the spudger, separate the motherboard from the battery, which are both held together with a mild adhesive.
3 weitere Nutzer haben diese Anleitung absolviert.
11 Kommentare
Hello,
i’m looking for replacement of start/stop button micro switch. Do you know what is the switch number which i can look for?
Thank you
Where can I find a replacement Motherboard ? None of my buttons are responding and I can’t even do a Factory reset.
All that works is switching off and back on.
I have exact same issue. I sent my watch to official repair service to Split (Croatia) and they said they aren’t able to fix it. I can see only main screen of the watch, buttons don’t respond at all. Would like to know how to fix the issue.
