Zum Hauptinhalt wechseln
Garmin Forerunner 25 Battery Replacement
Was du brauchst
  1. Garmin Forerunner 25 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Battery Replacement: Schritt 2, Bild 1 von 1
    • Pry the old battery out using a plastic spudger.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Dustin Persohn
235 Reputation
2 Anleitungen geschrieben
IUPUI, Team S5-G3, Baechle Spring 2018 Mitglied von IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Mitglieder
5 Anleitungen geschrieben
11 Kommentare
Thanks for the guide - can you advise what what type/model/of replacement battery is required and whether they are readily available?
cherokeelad - Antwort
I need to know as well. What kind of battery is it? PD…????
girlie_360 - Antwort
Just look at the last picture. PD2430C1
Leandro Lind - Antwort
Well, is that really a photo of a Forerunner25? There is no identification of the watch in the photo. Also, the markings on the battery are faded. Does anyone have more info on this?
Stephen Miller - Antwort
That’s not the forerunner25. The correct battery for forerunner25 is PD2032C1
Adam Sowalsky - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 30
Letzte 30 Tage: 102
Insgesamt: 6,062
