Einleitung
The screen is a vital component to a digital smart watch. With the right tools, replacing the screen can be done efficiently and effectively.
Was du brauchst
Place the watch on a hard surface with the screen facing down.
Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
Unscrew the two T4 6 mm screws located on both sides of the motherboard.
Remove gold piece in the corner using the pointed side of the 4 spudger.
