Zum Hauptinhalt wechseln
Garmin Forerunner 25 Screen Replacement
Was du brauchst
  1. Garmin Forerunner 25 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power off your watch before disassembling it.
    • Place the watch on a hard surface with the screen facing down.
    • Unscrew the four 7.0 mm screws located at each corner using a T5 screwdriver.
  2. Garmin Forerunner 25 Screen Replacement: Schritt 2, Bild 1 von 1
    • Pry the old battery out using a plastic spudger.
  3. Garmin Forerunner 25 Screen Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Unscrew the two T4 6 mm screws located on both sides of the motherboard.
  4. Garmin Forerunner 25 Screen Replacement: Schritt 4, Bild 1 von 1
    • Lift the motherboard up using a plastic spudger.
    • Ribbon cables are still attached underneath—be careful when prying the motherboard up.
  5. Garmin Forerunner 25 Screen Replacement: Schritt 5, Bild 1 von 1
    • Flip the ZIF connectors using a plastic spudger tool.
    • Remove the motherboard.
  6. Garmin Forerunner 25 Screen Replacement, Screen: Schritt 6, Bild 1 von 1
    • Remove gold piece in the corner using the pointed side of the 4 spudger.
    • Any spudger with a pointed end should work to remove this piece.
  7. Garmin Forerunner 25 Screen Replacement: Schritt 7, Bild 1 von 1
    • Pry the screen up with a plastic opening tool.
    • Any plastic tool with a flat edge should work to remove the screen.
    • Remove the screen.
Abschluss
Suzanne Drumm
85 Reputation
1 Anleitung geschrieben
IUPUI, Team S5-G3, Baechle Spring 2018 Mitglied von IUPUI, Team S5-G3, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 12
Insgesamt: 1,680
