Zum Hauptinhalt wechseln
Garmin GPS V Button Pad Replacement
Was du brauchst
  1. Garmin GPS V Button Pad Replacement, Logic Board: Schritt 1, Bild 1 von 3 Garmin GPS V Button Pad Replacement, Logic Board: Schritt 1, Bild 2 von 3 Garmin GPS V Button Pad Replacement, Logic Board: Schritt 1, Bild 3 von 3
    • Orient the GPS V backside up.
    • With a #0 Philips screwdriver, remove six M2x0.4 black screws on the back of the unit.
  2. Garmin GPS V Button Pad Replacement: Schritt 2, Bild 1 von 2 Garmin GPS V Button Pad Replacement: Schritt 2, Bild 2 von 2
    • With the spudger, gently pry the back plate off the unit starting at the corners.
    • Open the back plate about 35°, use the antenna side act like a hinge.
    • Do NOT remove the back plate all the way, there are cables connected to it.
  3. Garmin GPS V Button Pad Replacement: Schritt 3, Bild 1 von 2 Garmin GPS V Button Pad Replacement: Schritt 3, Bild 2 von 2
    • Locate the white 8-pin connector on the logic board and disconnect it.
    • Open the device all the way, making sure to not disconnect the brown antenna wire.
  4. Garmin GPS V Button Pad Replacement: Schritt 4, Bild 1 von 2 Garmin GPS V Button Pad Replacement: Schritt 4, Bild 2 von 2
    • With a #1 Philips screwdriver, remove the silver M2x0.4 screw on the logic board near the brown wire.
    • You may need to rotate the device to get better access to the screw.
  5. Garmin GPS V Button Pad Replacement: Schritt 5, Bild 1 von 3 Garmin GPS V Button Pad Replacement: Schritt 5, Bild 2 von 3 Garmin GPS V Button Pad Replacement: Schritt 5, Bild 3 von 3
    • Locate the ribbon connector on the logic board.
    • With the spudger, gently apply pressure to both sides of the brown connector lock until it pushes out.
    • With the spudger, gently work the ribbon cable out of the connector until it is free.
  6. Garmin GPS V Button Pad Replacement: Schritt 6, Bild 1 von 2 Garmin GPS V Button Pad Replacement: Schritt 6, Bild 2 von 2
    • With the spudger, gently pry out the logic board.
    • Be careful to not disconnect the brown antenna wire as you remove the logic board.
  7. Garmin GPS V Button Pad Replacement: Schritt 7, Bild 1 von 1
    • Locate the brown wire connection on the logic board.
    • Carefully apply heat with the soldering iron while gently pulling on the brown wire.
    • It may take some time to heat the flux up before the wire can be pulled out.
    • Pull brown wire free of the logic board.
  8. Garmin GPS V Button Pad Replacement, Button Pad: Schritt 8, Bild 1 von 3 Garmin GPS V Button Pad Replacement, Button Pad: Schritt 8, Bild 2 von 3 Garmin GPS V Button Pad Replacement, Button Pad: Schritt 8, Bild 3 von 3
    • Gently pry the button pad off of the front plate.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Connor
194 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 3-25, Amido Winter 2012 Mitglied von Cal Poly, Team 3-25, Amido Winter 2012
CPSU-AMIDO-W12S3G25
4 Mitglieder
Ein Kommentar
Hey, a have an old Garmin GPS III and my problem is that the GPS can not find any satelliters. I have opened back plate and I think its looks ok inside.
What can I do?
Best regards
Christian Tregert
Ctregert@hotmail.com
ChristianTregert - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,455
