Einleitung
If you know your batteries are not the problem, but your device will not power on, your battery terminals may be corroded. The following is a guide on how to replace battery terminals on the Garmin GPSmap 60CSx.
Was du brauchst
Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
Place spudger behind the lower right battery terminal.
Push spudger behind the battery terminal to pop it out of place.
Now do the same on the bottom left side.
Flip the back panel over to expose the backs of the top battery terminals.
Use a metal spudger to remove the glue that covers them.
Flip the back panel back over to view the battery compartment.
Place the spudger behind one of the top remaining battery terminals.
Push the spudger down and pop the battery terminal out of place.
Repeat with the remaining battery terminal.
9 Kommentare
What did you use to replace the contacts?
Mitch, Garmin just told me they do no sell replacement terminals for this 60CSx. Were you able to find any?
Where can I find replacement battery terminals for a
Garmin 60CS4?
