Einleitung
The gasket can break and become unusable, compromising the protection of the internal structure of device and rendering it vulnerable to water. This guide will aid you in its removal and replacement.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Lift and twist the battery cover release  90 degrees counterclockwise on the back of the device.
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Lift battery release up to remove battery cover.
    • Lift battery release up to remove battery cover.
    • Pull AA batteries out.
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 Screwdriver.
    • Separate the back panel from the front.
    • Remove the gasket.
    • Be careful to make sure the gasket is aligned correctly to ensure it is water proof.
Abschluss
Statistik anzeigen:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 25
Insgesamt: 268
