Zum Hauptinhalt wechseln
Garmin GPSmap 60CSx Keypad Buttons Replacement
Was du brauchst
  1. Garmin GPSmap 60CSx Keypad Buttons Replacement, Back Cover and AA Batteries: Schritt 1, Bild 1 von 1
    • Lift and twist the battery cover release 90 degrees counterclockwise on the back of the device.
  2. Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 2, Bild 1 von 1
    • Lift battery release up to remove battery cover.
  3. Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 3, Bild 1 von 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 3, Bild 2 von 2
    • Pull AA batteries out.
  4. Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: Schritt 4, Bild 1 von 2 Garmin GPSmap 60CSx Keypad Buttons Replacement, Keypad Buttons: Schritt 4, Bild 2 von 2
    • Remove the six 10 mm screws on the back of the device with a Phillips #0 screwdriver.
    • Flip the back panel over to view the green electronics board (the PCB) and the PCB covering.
    • Remove the black, yellow, blue, and red wires connected to the PCB with light force.
  5. Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 5, Bild 1 von 1
    • Place the spudger in the bottom right corner of the black PCB cover and pry the corner out.
    • The previous step will need to be done to the other three corners.
    • It is best to do the two bottom corners first.
    • Pull the black PCB board out of the GPSMap 60 CSx.
  6. Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 6, Bild 1 von 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 6, Bild 2 von 2
    • Carefully use a spudger to lift the PCB a few centimeters.
    • Pull the PCB out towards the bottom of the GPSMap 60CSx.
    • This will pull out all the main components including the antenna and the screen.
  7. Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 7, Bild 1 von 2 Garmin GPSmap 60CSx Keypad Buttons Replacement: Schritt 7, Bild 2 von 2
    • Take the front panel and apply light force to the buttons.
    • The buttons are part of one unit and should all pop out at once.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 2,611
