Zum Hauptinhalt wechseln
Garmin Nüvi 52LM Disassembly
Was du brauchst
  1. Garmin Nüvi 52LM Disassembly, Garmin Nüvi 52LM Disassembly: Schritt 1, Bild 1 von 2 Garmin Nüvi 52LM Disassembly, Garmin Nüvi 52LM Disassembly: Schritt 1, Bild 2 von 2
    • Place the device face-down, with the screen facing the surface. There are 8.7mm screws located in each of the back 4 corners of the device. Using a T5 Torx screw bit, unscrew all four screws and leave them aside.
  2. Garmin Nüvi 52LM Disassembly: Schritt 2, Bild 1 von 2 Garmin Nüvi 52LM Disassembly: Schritt 2, Bild 2 von 2
    • Place a plastic opening tool in the seam between the back and front plates of the device. Using constant pressure, slowly and continuously slide the tool along the seam. The tool should disable each of the hooks holding the two plates together. If unsuccessful, apply slightly more pressure and try again.
    • Once all hooks are disabled, slowly separate the two plates, being careful not to damage the ribbon wire still connecting the two.
Abschluss
Diya Jamwal
101 Reputation
1 Anleitung geschrieben
Cal Poly, Team 10-1, Banghart Winter 2017 Mitglied von Cal Poly, Team 10-1, Banghart Winter 2017
CPSU-BANGHART-W17S10G1
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 454
