Einleitung
Opening the Nuvi and replacing a broken/damaged display.
Was du brauchst
Peel off the sticker from the bottom of the device to reveal two screws.
Insert a plastic opening tool in the gap between the front and rear casing.
Carefully work the tool around the gap, separating the two halves of the case.
Apply pressure to the tabs holding the screen in place with the plastic opening tool
4 weitere Personen haben diese Anleitung absolviert.
