Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
Replacing the speaker in a Garmin Nuvi 200.
  1. Peel off the sticker from the bottom of the device to reveal two screws. Peel off the sticker from the bottom of the device to reveal two screws.
    • Peel off the sticker from the bottom of the device to reveal two screws.
  2. Remove two T5 Torx screws.
    • Remove two T5 Torx screws.
  3. Insert a plastic opening tool in the gap between the front and rear casing. Carefully work the tool around the gap, separating the two halves of the case.
    • Insert a plastic opening tool in the gap between the front and rear casing.
    • Carefully work the tool around the gap, separating the two halves of the case.
    • Keep the power switch in place while removing the rear case.
  4. Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
    • Unscrew the two screws on opposite sides of the speaker using the #00 Phillips screwdriver.
  5. Pull the cable out to detach the speaker from the logic board.
    • Pull the cable out to detach the speaker from the logic board.
  6. Wedge the iPod opener into the space between the speaker and the case. Apply pressure to pry the speaker away from the case. Apply pressure to pry the speaker away from the case.
    • Wedge the iPod opener into the space between the speaker and the case.
    • Apply pressure to pry the speaker away from the case.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Anjelica
519 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 25-90, Amido Spring 2010 Mitglied von Cal Poly, Team 25-90, Amido Spring 2010
CPSU-AMIDO-S10S25G90
4 Mitglieder
9 Anleitungen geschrieben
just a note i had a problem with the speaker in my nuvi 200 an upon opening up found speaker plug had come loose i guess from being dropped a few times pushed plug in an works fine please check all connections before replacing your speaker saved me $$ thanks for a great site everyone...
randaleholland - Antwort
Where can you buy replacement speakers for the Garmin units?
Brat Fry - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 8
Insgesamt: 6,751
