Zum Hauptinhalt wechseln
Garmin Nuvi 200W Rear Cover Replacement
Was du brauchst
  1. Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Garmin Nuvi 200W  Rear Cover Replacement, Rear Cover: Schritt 1, Bild 3 von 3
    • Peel off the sticker in order to find the two Torx T5 screws.
  2. Garmin Nuvi 200W  Rear Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 4mm T5 Torx screws.
  3. Garmin Nuvi 200W  Rear Cover Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 200W  Rear Cover Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 200W  Rear Cover Replacement: Schritt 3, Bild 3 von 3
    • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
    • Once you have a little gap, work it around the whole device with the tool to get separation.
    • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
  4. Garmin Nuvi 200W  Rear Cover Replacement: Schritt 4, Bild 1 von 2 Garmin Nuvi 200W  Rear Cover Replacement: Schritt 4, Bild 2 von 2
    • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
Abschluss
Matthew Eires
319 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S5-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 4
Letzte 30 Tage: 10
Insgesamt: 254
