Zum Hauptinhalt wechseln
Garmin Nuvi 200w Battery Replacement
Was du brauchst
    1. Garmin Nuvi 200w Battery Replacement, Rear Cover: Schritt 1, Bild 1 von 3 Garmin Nuvi 200w Battery Replacement, Rear Cover: Schritt 1, Bild 2 von 3 Garmin Nuvi 200w Battery Replacement, Rear Cover: Schritt 1, Bild 3 von 3
      • Peel off the sticker in order to find the two Torx T5 screws.
      Frag FixBot
      Kommentar hinzufügen
    2. Garmin Nuvi 200w Battery Replacement: Schritt 2, Bild 1 von 1
      • Remove the two 4mm T5 Torx screws.
      Frag FixBot
    3. Garmin Nuvi 200w Battery Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 200w Battery Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 200w Battery Replacement: Schritt 3, Bild 3 von 3
      • Carefully, using your plastic opening tools find the crease which separates the front and rear covers.
      • Once you have a little gap, work it around the whole device with the tool to get separation.
      • There is a ribbon cable between the two covers, be very careful when taking them apart to not damage the ribbon.
      Frag FixBot
    4. Garmin Nuvi 200w Battery Replacement: Schritt 4, Bild 1 von 2 Garmin Nuvi 200w Battery Replacement: Schritt 4, Bild 2 von 2
      • After the case front and rear are separated, carefully lay the two sides down without disconnecting or damaging the orange ribbon cable.
      Frag FixBot
    1. Garmin Nuvi 200w Battery Replacement, Display Assembly: Schritt 5, Bild 1 von 3 Garmin Nuvi 200w Battery Replacement, Display Assembly: Schritt 5, Bild 2 von 3 Garmin Nuvi 200w Battery Replacement, Display Assembly: Schritt 5, Bild 3 von 3
      • Carefully use the black spudger to lift the white retaining clamp on the display cable ZIF connector.
      • Make sure to lift up on the white retaining clamp and not the ZIF connector itself.
      • Slide the orange ribbon cable away from the ZIF connector.
      Frag FixBot
    1. Garmin Nuvi 200w Battery Replacement, Motherboard: Schritt 6, Bild 1 von 2 Garmin Nuvi 200w Battery Replacement, Motherboard: Schritt 6, Bild 2 von 2
      • Using a screw driver, unscrew the four 2mm screws holding the motherboard in place.
      • Gently lift the motherboard away from the rear cover. Take care to not damage the wires or ports that link the motherboard to other components.
      Frag FixBot
    2. Garmin Nuvi 200w Battery Replacement: Schritt 7, Bild 1 von 3 Garmin Nuvi 200w Battery Replacement: Schritt 7, Bild 2 von 3 Garmin Nuvi 200w Battery Replacement: Schritt 7, Bild 3 von 3
      • Using the black spudger, apply pressure to nudge the plug out of its port.
      • Repeat this process for both ports.
      Frag FixBot
    1. Garmin Nuvi 200w Battery Replacement, Battery: Schritt 8, Bild 1 von 3 Garmin Nuvi 200w Battery Replacement, Battery: Schritt 8, Bild 2 von 3 Garmin Nuvi 200w Battery Replacement, Battery: Schritt 8, Bild 3 von 3
      • Using your opening tools, separate the battery from the top side. Very slowly push your tool down into the crevice.
      • Be careful because the battery is glued to the rear cover, so it does take some force to separate.
      • Once you have a gap big enough, pull the battery off the cover.
      Frag FixBot
Abschluss
UMass Dartmouth, Team S5-G4, Botvin Spring 2017 Mitglied von UMass Dartmouth, Team S5-G4, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G4
3 Mitglieder
18 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 22
Insgesamt: 2,078
