Zum Hauptinhalt wechseln
Garmin Nuvi 2455LMT Speaker Replacement
Was du brauchst
  1. Garmin Nuvi 2455LMT Speaker Replacement, Speaker: Schritt 1, Bild 1 von 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver. Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
  2. Garmin Nuvi 2455LMT Speaker Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 2455LMT Speaker Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
  3. Garmin Nuvi 2455LMT Speaker Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 2455LMT Speaker Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 2455LMT Speaker Replacement: Schritt 3, Bild 3 von 3
    • Open the device carefully being weary of the orange band that is going from the screen to the mother board.
  4. Garmin Nuvi 2455LMT Speaker Replacement: Schritt 4, Bild 1 von 2 Garmin Nuvi 2455LMT Speaker Replacement: Schritt 4, Bild 2 von 2
    • Using the plastic prying tool, carefully pry the speaker from the plastic backing.
    • Remove the speaker from the motherboard by gently pulling on the wire.
Abschluss
USF Tampa, Team 2-3, Blackwell Fall 2016 Mitglied von USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 8
Insgesamt: 210
