Zum Hauptinhalt wechseln
Garmin Nuvi 2455LMT Touch Screen Replacement
Was du brauchst
  1. Garmin Nuvi 2455LMT Touch Screen Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 1
    • Remove the four 2.5mm screws from the back assembly with a Torx #04 Screwdriver.
    • Holding the GPS with a free hand while unscrewing the small screws will help stabilize the device.
    Frag FixBot
    Kommentar hinzufügen
  2. Garmin Nuvi 2455LMT Touch Screen Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 2455LMT Touch Screen Replacement: Schritt 2, Bild 2 von 2
    • Use the plastic opening tool on all four sides of the device to open the Garmin Nuvi LMT2455 Back Panel.
    • To properly remove the back cover assembly pry open both the back and sides of the assembly.
    Frag FixBot
  3. Garmin Nuvi 2455LMT Touch Screen Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 2455LMT Touch Screen Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 2455LMT Touch Screen Replacement: Schritt 3, Bild 3 von 3
    • Open the device carefully being wary of the orange band that is going from the screen to the motherboard.
    • Remove the orange band by carefully lifting the lip that connects it to the motherboard.
    Frag FixBot
  4. Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: Schritt 4, Bild 1 von 2 Garmin Nuvi 2455LMT Touch Screen Replacement, Touch Screen: Schritt 4, Bild 2 von 2
    • Locate the edge of the screen that fits into the plastic case
    • To separate the connector, gently push the tip of a spudger under the clip.
    • Then, swing the clip over to the other side of the socket, so that it lays flat against the cable.
    Frag FixBot
  5. Garmin Nuvi 2455LMT Touch Screen Replacement: Schritt 5, Bild 1 von 1
    • Use the plastic opening tool to wedge between the plastic cover and screen.
    • Using your hands, gently push the front of the screen towards you to push the screen out of the casing.
    Frag FixBot
Abschluss
USF Tampa, Team 2-3, Blackwell Fall 2016 Mitglied von USF Tampa, Team 2-3, Blackwell Fall 2016
USFT-BLACKWELL-F16S2G3
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 36
Insgesamt: 904
