Einleitung
The tools needed are a T5 Torx screwdriver and a plastic opening tool. The battery is glued to the back of the device and connected to the motherboard with a wire.
Was du brauchst
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
Carefully pull apart the device by opening it up on the opposite side of the nameplate.
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Would this apply to the Nuvi 2555LMT?
