Einleitung
The needed tools are a T5 Torx Screwdriver and a plastic opening tool. In order to get to the inside of the device the nameplate and the back of the device will be taken off.
Was du brauchst
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
Carefully pull apart the device by opening it up on the opposite side of the nameplate.
Eine weitere Person hat diese Anleitung absolviert.
